Dash Fault flashes when starting car 1995 1.8t
RE: Dash Fault flashes when starting car 1995 1.8t
its not a fault it just means its due a service and the light has to be cleared and here is how.
button A is the odometer under the speedo and B is the dimmer under the rev counter.
OEL-OIL service light
press and hold button A,
switch ignition on,
release button A,
the letters OEL or OIL will appear in the odometer display of the speedometer.
pull out button B until the letters are erased and replaced by *--*
that's the oil service light reset..
now the inspection service light.
press and hold button A.
switch ignition on.
release button A.
the letters INSP will appear in the odometer display of the.
if required clear the OEL-OIL indicator from the display as previously described
switch ignition on,
release button A,
switch ignition on.
release button A.
5th_year_senior
11-08-2009 02:11 PM
