Damp Floor on the Drivers side
Hi, I have an 04 A4 Cab, 9k pretty much in immaculate condition.. Only bought it a few weeks ago, anyway, I noticed that under the floor mat, the carpet was very damp... Now before you automatically assume cos its a cab, its roof has had a leak, I will add, there is NO noticable water marks on the softtop... For enough water to drip onto the mat and through to the carpet, I would assume there would be some water marking on the inside of the grey velour. Plus I've been inside the car during a typical Floridan HEAVY rain storm.. No water came through the roof whatsoever. I guess the car is under warranty so I'll end up taking to Audi, but any idea's as to what else it could be? Condensation from the AC making it's way down there? I'm lost....
RE: Damp Floor on the Drivers side
I had this happen on my Lexus! It was my evaporation core that had a small crack! I fixed mine withepoxy and held up fine. It was a pain in the *** to get to the Evap core as it is located under the dash and all that has to come out to get to the part. NowI dont know if this is where it is on the A4 butI would almost assume it would be!
where in florida are you at?
i had the same problem but mine wasn't a cab. my sunroof drain plug was leaking and allowing water to come in by the pedals. if there's no water marks on the inside of your roof than you can rule out the roof. only other place i can think of that could get the driver's side wet is somewhere in the driver side firewall. did you check behind the driver side seat? cuz thats where the water pooled in my car and you would wana vacuum that out so your carpet doesn't reek
but ya since its still under warranty, make it audi's problem not yours
5ln
02-23-2009 05:19 PM
dan4g63
01-01-2009 10:51 PM
nick17
11-11-2008 10:44 PM
TeeterTawter
08-20-2007 01:37 PM
