which cylinders does pre cat o2 run?
RE: which cylinders does pre cat o2 run?
well the only thing i could think of would be that i use a 3" maf housing from a vr6 and my pre cat o2 may be bad. the only other thing is that i put a filter on the pipe that comes off the valve cover that goes into the air intake system. now what do think my problem may be? thanks alot for the replies
ORIGINAL: goldenchild
I think you just answered your question. You may have a leak within the pipe that goes into the air intake. I am not an expert, but it was just my guess that your problem lies within the stuff that you changed.
well i plugged off the hole on the intake and put a breather filter on it just like the lltek kit and other cai kits use. i wouldnt think this would do anything but i just switched back my maf housing to stock bc since i put a larger one on the computer is seeing less cfm so it will lean out the car. i figured i could fix that by putting larger injectors and a adjustable fpr
