which cylinders does pre cat o2 run?
RE: which cylinders does pre cat o2 run?
your o2 senors help to determine your long term and your short term fuel trim for all cyclinders. Just because you have an O2 code showing up it's a bad idea to start condeming o2's....gets expensive fast. If your getting a lean code, chances are your not having an o2 issue it's more related to a cyclinder actually leaning out...possibly a plugged fuel injector. What do you other guys think?
What engine do you have? On the 1.8t the precat o2 monitors all 4 cylinders. On the V6 there is 2 pre cat sensors. Each one monitors one bank or side of the engine.
P0170 - Fuel trim malfunction (bank 1)
P0171 - System too lean (bank 1)
Have you checked your oil filler cap? Broken oil dipstick?
Intake Air leak?
MAF sensor??
Faulty 02 sensor?
No way I can pinpoint what it is exactly. You are going to have to do some elimination.
Intake Air leak?
MAF sensor??
Faulty 02 sensor?
ORIGINAL: Jestnomen
Intake Air leak?
MAF sensor??
Faulty 02 sensor?
Intake Air leak?
MAF sensor??
Faulty 02 sensor?
Could this also be caused by a DV going south?
