Sponsored by:
Sponsored by:
which cylinders does pre cat o2 run?
Old 07-26-2005, 09:34 PM
goldenchild's Avatar
Default which cylinders does pre cat o2 run?
simply stated. need to know bc i keep throwing 170 and 171 codes. i changed my after cat one and it helped a little but not a whole lot
Old 07-26-2005, 11:38 PM
david9999's Avatar
Default RE: which cylinders does pre cat o2 run?
Please post the whole code and which engine/ year you have. Then we might be able to answer reasonably.
Old 07-27-2005, 12:03 AM
those are the codes 170 is a fuel interupt and 171 is too lean. im more less wanting to know what cylinders the pre o2 sensor determines for the fuel
Old 07-27-2005, 04:44 AM
your o2 senors help to determine your long term and your short term fuel trim for all cyclinders. Just because you have an O2 code showing up it's a bad idea to start condeming o2's....gets expensive fast. If your getting a lean code, chances are your not having an o2 issue it's more related to a cyclinder actually leaning out...possibly a plugged fuel injector. What do you other guys think?
Old 07-27-2005, 07:28 AM
david9999's Avatar
Could be MAF, air leak, vacuum leak or dirty injectors.
Old 07-27-2005, 09:57 AM
well it the rear 2 cylinders im having the trouble with. what is some good stuff to clean my injectors with
Old 07-27-2005, 01:48 PM
Jestnomen's Avatar
6th Gear
What engine do you have? On the 1.8t the precat o2 monitors all 4 cylinders. On the V6 there is 2 pre cat sensors. Each one monitors one bank or side of the engine.
Old 07-27-2005, 02:20 PM
o ya sorry it is a 1.8t. well then what would be causing me to have the rear 2 cylinders fowling out the plugs and getting those codes?
Old 07-27-2005, 02:43 PM
Jestnomen's Avatar
6th Gear
P0170 - Fuel trim malfunction (bank 1)
P0171 - System too lean (bank 1)
Have you checked your oil filler cap? Broken oil dipstick?
Intake Air leak?
MAF sensor??
Faulty 02 sensor?
No way I can pinpoint what it is exactly. You are going to have to do some elimination.
Old 07-27-2005, 02:47 PM
dudley doright's Avatar
ORIGINAL: Jestnomen
Intake Air leak?
MAF sensor??
Faulty 02 sensor?
Jest,
Could this also be caused by a DV going south?
Quick Reply: which cylinders does pre cat o2 run?
