Cylinder 6 misfire 1998 Audi a4 2.8 quattro
Old 02-10-2014 | 08:57 PM
thelastgood1forever's Avatar
Default Cylinder 6 misfire 1998 Audi a4 2.8 quattro
Just recently (2/09/14) I got codes p1127 and p1129. Before I got them, the car was idling very rough and randomly stalling. I cleaned the MAF with CRC MAF cleaner and it seemed to do the trick. The car was idling smooth and it never stalled when driving around town. On Monday, the check engine light came back on -(when I got codes p1127 and p1129, the light flashed for a couple of seconds then became solid when I put it into gear, I have learned that a flashing CEL means a misfire, but when I had it checked 5 minutes later, there was nothing about a misfire, any ideas here?) Today, I took it back to O'reilly's to have the light checked. The man said it was cylinder 6 misfire (I never got the code number). He initially thought the computer gave a false diagnostic and cleared the light. I started the car and the light immediately came back on, same problem. He said it is rare to find a single cylinder misfire. He mentioned that either the coil pack or ignition wires are bad. He ordered in a set of ignition wires to begin with. Now before I spend $150+ on those wires, I want to get some other possible ideas. I know the spark plugs and vacuum lines have recently been replaced (I've had the car for about a month, purchased it from an audience technician). What are some other things to cause a misfire on a single cylinder?
thelastgood1forever
02-13-2014 12:28 AM
polishmatt
04-26-2013 09:59 PM
mmdambro
05-14-2011 11:41 PM
hjeff
10-17-2009 11:42 AM
dcshus
10-12-2009 05:09 PM
Quick Reply: Cylinder 6 misfire 1998 Audi a4 2.8 quattro
