Sponsored by:
Sponsored by:
Creaking Noise
Old 08-24-2005, 02:26 PM
yellowa4's Avatar
Member
Default Creaking Noise
2000 A4 1.8T Q
I'm getting a low creaking noise at the first turn of the steering wheel after ignition. Also, at low speeds I am getting a different creaking noise after going over uneven road.
Could this be a tie rod issue? Pls.. any advice would be greatly appreciated.
B
Old 08-24-2005, 02:39 PM
Toff_the_Toffee's Avatar
Default RE: Creaking Noise
I had my tie rods greased when i had squeaks and creaks...sorted it out no problem.
Old 08-24-2005, 02:54 PM
S_R_N83's Avatar
I also had them greased, and it helped. I would try that first.
Old 08-24-2005, 03:29 PM
BzeA4's Avatar
I'm having some creaking too, yet i have new front control arms and tie rods, i've read about the possibility of it being the bushings, has this ever happened to anyone?
Do you think greasing/lubing it will help?
Old 08-24-2005, 03:49 PM
yellowa4's Avatar
Member
thanks!
I'll try the greasing first and will let you know how it pans out.
would this be related to the creaking at the first turn of the wheel after ignintion?
B
Old 08-24-2005, 07:38 PM
sandman's Avatar
if that doesnt work try changing them, its pretty easy
http://www.audiworld.com/tech/wheel.html
heres where i got a heavy duty tierod end
http://www.ecstuning.com/stage/edpd/...gory=Tie%20Rod
Old 08-25-2005, 11:28 AM
yellowa4's Avatar
Member
thanks sandman!
gonna greas'em up first before spending the ducketts on new ones. if a replacement is needed, I spend the xtra on HDs. I'll keep y'all posted.
B
Old 08-26-2005, 05:57 AM
lidonnit's Avatar
If your car has done 75,000 miles it might be worth changind the tie rods. They tend to fail on our cars which can lead to some pretty hairy moments.
Old 08-26-2005, 01:56 PM
yellowa4's Avatar
Member
thanks lidonnit!
i have about 62K miles at the moment... the creaking only occurs at slow speeds but it's quite noticeable
i'm not very mechanically inclined so i'll probably go to a shop for it... otherwise it's the dealership... tune up is come soon anyway so i'll probable have it done next week
keep y'all posted
Old 08-26-2005, 02:14 PM
yellowa4's Avatar
Member
does anybody know how much labour is required to replace the tie rod ends? Part Price also? I'm looking at taking it to the dealership and i would like to be a little prepared in the event I get sticker shock
thanks B
Quick Reply: Creaking Noise
