Crazy Question
RE: Crazy Question
im suprised cincy didnt beat you down...
no lost horsepower, you just wont gain much without the correct supporting mods...
build up to the BT, not around it
now that i think about it, i wonder what tuner would actually give you a flash without exhaust, test pipe and fmic... my revo dealer wouldnt give me the stage II flash without a testpipe, FMIC and intake and he wanted an exhaust to be on it first too...
RE: Crazy Question
Why would i beat them down?
Those mods are recommended, but not 100% required. You would make more power with a catback, but it shouldnt stop them from giving you a tune. Its basically because w/o those mods your timing that they add would get pulled and you wouldnt see nearly the gains as you would if you had them done. Not a huge deal, i would of told you so and then flashed you if i was them
RE: Crazy Question
I asked because i wanted to put them on, i have all the supporting mods (minus clutch and flywheel) and drive to get a reflash for BT (Revo). Im trying to make sure i wont be a hazard on the road. Theyve been sitting in my garage now for about 4 months
RE: Crazy Question
Then install everything but the injectors, get flashed and then install the injectors before you leave. Just run the boost of the wastegate to get flashed.
BTW, that would of been a much better 1st post
