Sponsored by:
Sponsored by:
Combination of Codes from the VAG
Old 03-01-2006, 03:57 PM
Sebass's Avatar
Default Combination of Codes from the VAG
02 B6 A4 1.8t 67k miles
VAG-COM Version: Release 409.1-US
Chassis Type: 8E - Audi A4 B6
Scan: 01,02,03,08,09,15,16,17,26,36,37,45,46,55,56,63,76
Address 01: Engine
Controller: 8E0 909 518 F
Component: 1.8L R4/5VT G 0001
Coding: 0016751
Shop #: WSC 63351
1 Fault Found:
17544 - Fuel Trim: Bank 1 (Add): System too Lean
P1136 - 001 - Upper Limit Exceeded - Intermittent
Readiness: 0000 0000
Address 08: Auto HVAC
Controller: 8E0 820 043 G
Component: A4 Klimaautomat 0712
Coding: 00000
Shop #: WSC 63351
1 Fault Found:
00604 - Potentiometer Positioning Motor for Air Flow Flap (G113)
30-10 - Open or Short to B+ - Intermittent
I know the top one is probably a vac hose...it has been in the past...but what about the combination with this bottom code...never seen it...problem is...the woman and I are going skiing and this is the only car we can drive...am I gonna screw it up worse if I put 400 more miles on it?
Old 03-01-2006, 04:07 PM
drkenan's Avatar
Default RE: Combination of Codes from the VAG
Did you try to clear it and see if it came back?
Old 03-01-2006, 04:34 PM
I think you got the second code wrong
1 of 2
[IMG]local://upfiles/12092/9CFBD61505AA41B2B62E6141181F4746.jpg[/IMG]
Old 03-01-2006, 04:42 PM
2, I was thinking code 16504 but it not important I think it could be a combination
[IMG]local://upfiles/12092/DECC9EDB46DA46C18BDC7A8528294491.jpg[/IMG]
Old 03-01-2006, 04:53 PM
vag codes 006 start at 00609
Old 03-01-2006, 04:59 PM
as you can see
[IMG]local://upfiles/12092/34D87E844AAD4B31A8E089CEE9F33891.jpg[/IMG]
Old 03-01-2006, 05:28 PM
hopefully people will save this data for future reference "there are 28 pages", one day when im real Bord ill set about scanning them and converting them to jpeg then resizing then, a lot of work
Old 03-01-2006, 05:53 PM
brrman's Avatar
"Potentiometer Positioning Motor for Air Flow Flap (G113)"
Having climate control issues? Possible low voltage issue or bad ground on that line. Sometimes a bad coolant temp sensor can make the flap motor act funny too.
Old 03-01-2006, 07:57 PM
Sebass's Avatar
avant, those are exact clipboard copies from the VAG software...
brrman, yes it has been blowing cold air very infrequently when driving for long periods of time...and then kind of normalizes eventually...
and yes I cleared the codes, and the first one came back...the second one wasn't there when I cleared em the first time...
Old 03-02-2006, 05:12 PM
VAG software... I dont think so mate (AUTODATA)
Quick Reply: Combination of Codes from the VAG
