Sponsored by:
Sponsored by:
collapsed suspension
Old 10-16-2007, 12:27 PM
densil's Avatar
Default collapsed suspension
hi , im new here , just wondering what you guys think of this situation.
about a year and a half ago i took my 95 A4 to a recall for the suspension, it was givin the all clear and that was that,
until this morning, i stopped at the lights and heard a loud bang, the passenger side wheel had clean snapped off from the suspension, i couldnt believe it. do you recon i have any come back with audi or the garage where the test was done previously, any help is welcome thanks
Old 10-16-2007, 12:31 PM
The Russian's Avatar
Default RE: collapsed suspension
if there was a recall and the dealerhsip shows no records of you getting it, i don't see why they wouldn
t do it, give them a call and tell them your vin
Old 10-16-2007, 12:53 PM
ocadam's Avatar
Are you sure it was your suspension? Are all you your bolts on there, maybe all your bolts came off then the wheel just feel off.
Old 10-16-2007, 01:51 PM
densil's Avatar
no its clean snapped of ,,the wheel is still attached to everything, but further back the steel is broken in two, the guy in the tow truck said hed only ever seen cars like this after a bad accident, lucky i was stopped when it happened
Old 10-16-2007, 01:55 PM
ocadam's Avatar
[quote]ORIGINAL: densil
[/quote
very true you dodged a bullet there.
Old 10-16-2007, 03:02 PM
chaos92287's Avatar
it all depends on what broke and what the recall was for, but yeah i would take it back to the place for sure
Old 10-16-2007, 03:14 PM
not uncommon and down to age and maintenance like under seal ( finnegans wax oil under seal recommended ), they break where the spring sits, don't try to weld it because it will explode go to breakers yard or recon unit
[IMG]local://upfiles/12092/CA843D9DAAD34D13A55706E8B872B1E3.jpg[/IMG]
Old 10-16-2007, 03:48 PM
hiwords's Avatar
wut is a 95 A4?
Old 10-17-2007, 10:46 AM
densil's Avatar
an audi a4 straight from the year 1995
Old 10-17-2007, 12:22 PM
SAudi's Avatar
yeah mine is a 95 also, or say the Date of manufacture says, 06/95. it sucks i dont have a sunroof, it was standard on the A4
Quick Reply: collapsed suspension
