Sponsored by:
Sponsored by:
cold idle RPM question, possible problem?
Old 11-03-2006, 04:38 PM
onepoint8tee's Avatar
Default RE: cold idle RPM question, possible problem?
ORIGINAL: new2me
My car does the same thing and it is only when the temp is at or below 35. I was told its not a problem. The only theory i can come up with is since its really cold the motor needs to be brought up to temp slower to prevent damage to parts. And oil is thicker which will circulate slower.
That makes sense.
Old 11-03-2006, 04:54 PM
kpatz's Avatar
Thanks guys. Guess it's fine then. I just wanted to make sure I didn't have a balky temperature sensor or something making the 'puter think the engine was warm or something. [8D]
Old 11-03-2006, 05:13 PM
ORIGINAL: kpatz
Depending on your mileage, its not that bad of an idea to replace the temp sensor anyway. They get corroded over time and can have shifty sensing which = shifty engine performance at start up and normal running temps.
justinclarke
11-25-2010 04:03 PM
hankeester
12-21-2005 09:35 PM
mikehh
12-16-2005 02:54 PM
Quick Reply: cold idle RPM question, possible problem?
