Code Problem Help! Help!
Hey,
2000A4 1.8T Quattro. I woke up this morning and start the car, theengine light was on. So I got itscan for the code & the code I got was (P1113). So can someone tell me what causing the problem for the engine light to come on. And also a few suggestions on how to fix the problems.
Thank You
Thank You
RE: Code Problem Help! Help!
By the way, check for a vac leak. I got that same code when I had a vac leak on one of the check valves on the back/top of the engine that works with the 2ndary air pump. Engines that have a 2ndary air pump for emissions at startup are 99.5 or 2000+. I replaced the cracked valve, cleared the code, and it has not come back so far. If you want to know which valve exactly check this out: There are lots spots in that general area that can spring a leak: https://www.audiforums.com/fb.asp?m=470168
