Clutch upgrade
RE: Clutch upgrade
ORIGINAL: clconversion
what clutch are you using Tom i've heard through the grape vine you are still running stock which is very hard to believe ?
RE: Clutch upgrade
Good call AB1618, that's what I've got. I can't remember what the model number was, sorry. Other than a little filing to get the flywheel on, it was a pretty easy install. Here's the site if you want to check it out. South Bend Clutch. HTH
