Clutch problem
Clutch problem
Hi there,
Please help me.
I have a audi a4 '00
I can't get the car into gear when running.
When I trun of the engine the clutch seems to works again and I can get the car into the wanted gear.
Only when the car is started (or being started) the clutch does not seem to do it's work.
I have looked arounf the internet but couldn't come up with anything except maybe the computer?
Thanks in advance for your reply.
Please help me.
RE: Clutch problem
Hi,
tnx for the fast replies.
I tried to start the car by putting it in 2nd gear and when i truned the key the car broke foward.
This for some reason made the clutch working again.
Maybe the plates where stuck? The clutch is oke (for now), but probably this will happen more often, any new toughts with this new information?
thanks again
thanks again
RE: Clutch problem
Hi,
No it works as it should be at this moment. not going slack at all, If I didn't knew something was wrong you would not experience it right now.
It looks solved for the timebeing, but I can 't believe that.
with regards.
with regards.
RE: Clutch problem
your pressur plate i just had mine redone. i had a stage 2 spec and replaced it with the same.
you will need a new flywheel. it will have hot spots on it and they are not cheep...i had to get a used one....oem $800 race $600 junkyard $80
Matt_Iliketurbopull
05-01-2007 05:28 PM
Matt_Iliketurbopull
04-28-2007 03:06 PM
