clunking noise when stopping
Old 07-31-2006 | 04:05 AM
jessnjoe's Avatar
Default clunking noise when stopping
i've been having this problem now for about a couple of weeks when ever i'm slowing down to stop at slow speeds i feel and hear a clunk from the front of my car it only happens just as i'm about to stop and the car settles, i can feel it in the steering wheel and in the brake pedel. Sometimes when i go over bumps at slow speeds i hear and feel it again, so i've checked control arms, bushings, but don't know where else to check everything that connects to the wheel is tight any other suggestions it's driving me nuts? thanks
Old 07-31-2006 | 09:07 AM
david9999's Avatar
Default RE: clunking noise when stopping
Control arms or tie rod ends likely
Old 07-31-2006 | 12:42 PM
jessnjoe's Avatar
i took it to the shop and they said that the control arms and tie rods were fine, the shop wasn't a true audi shop i just knew someone that could look at real quick for me but what else do you think it could be?
Old 07-31-2006 | 12:45 PM
onepoint8tee's Avatar
If you have tiptronic/auto tranny, it could be that the feeling is when it downshifts when you come to a stop. Ive heard that dirty connections under the car on the tranny's wiring harness/conncectors can cause that, and you should clean them. If your not tip. dont worry about that then. i dont know what else it could be if your control arms/tie rods are good.
Old 07-31-2006 | 01:58 PM
InsaneHatter's Avatar
Could be a bad CV, when mine went terribly bad it would clunk really hard under braking. but more than once.
Old 07-31-2006 | 02:02 PM
Also your front engine/snub mount might be rotted out. It helps as a buffer for when the engine rocks back and forth during acceleration/shifting/downshifting. If its bad youll have more slack in the egnine movements which will generate a clunking feel during those situations.
fer2367
Audi Q5
08-22-2012 11:22 PM
AirMax95
11-02-2008 10:12 PM
WasWrxDriver
12-02-2006 01:33 AM
rob1234
10-04-2006 05:14 PM
sandman
10-15-2005 09:45 AM
Quick Reply: clunking noise when stopping
