Climate Control Sensor/Calibration
Old 03-07-2007 | 03:54 PM
clifty's Avatar
Default Climate Control Sensor/Calibration
Have a problem with climate control in my 2002 A4 Avant (UK model). The air con unit works fine, as does the heating, but the climate control temperature sensors are not behaving. When I set the unit to LO the fans go to full and the air con kicks in as expected. However when I move the selected temperature up one click (to 18 degrees) the unit switches back to heating, even thoughI know the car temperature is well above this value.
Is this a broken sensor, or just a calibration issue?
Old 06-21-2007 | 01:35 PM
a8audiv8's Avatar
Default RE: Climate Control Sensor/Calibration
Deleted
Old 12-21-2015 | 12:16 PM
ad1452's Avatar
Clifty - this is an old post but I have the same issue with my A4, switching the temp up one notch turns the heat on full! Did you work out what the issue was?
Thanks
skonstantin
08-21-2012 09:32 AM
hiwords
11-18-2007 11:22 AM
cian_ie
01-10-2007 07:07 PM
Suachris
06-16-2005 01:00 PM
Quick Reply: Climate Control Sensor/Calibration
