AudiForums.com
-   Audi A4 (https://www.audiforums.com/forum/audi-a4-8/)
-   -   Clicking noise from during low speeds? (https://www.audiforums.com/forum/audi-a4-8/clicking-noise-during-low-speeds-9220/)
cukilo 04-29-2005 02:11 AM
RE: Clicking noise from during low speeds?
I was almost sure that it was the CV joint since i had this problem with my civic about a year ago. I'll get it looked at next month and get back to you guys with an update.
david9999 04-29-2005 09:43 AM
I'll add to the clamor. That is classical for failing CV joint, most likely outer.
darksi3842 04-29-2005 11:19 AM
if it gets to the point that stuff like your transmission is shakking a little it is definatly you alignment
cukilo 04-29-2005 02:09 PM
How long can i drive like this? Because i am going to the US this weekend and i hope that it lasts for the trip there and back thats about 1600km?
Krule 04-29-2005 02:14 PM
ako ces do amerike naleti do Atlante brate ako stignes heheeh, al nevjerujem da bi trebo daleko vozit sa tako sjebanim cv joint ako mozes pogledaj sa autoshop nekim da vide jel sigurno ili ne nemoj bezveze rizikovat
BFlan2001 04-29-2005 02:59 PM
you should be fine.....failing cv joints will function fine for months...the damage is already done, you aren't hurting anything driving on it, just take it easy at low speed turns, if it gets really bad the joint will pop off and you'll be screwed, you'll have to get it towed....
