Sponsored by:
Sponsored by:
Clicking noise from during low speeds?
Old 04-28-2005, 03:32 PM
cukilo's Avatar
Default Clicking noise from during low speeds?
Hi gang i was hoping you might have a similar experience and know what the problem is. When i put the car in first and turn the wheel while moving very slow i get a click, click noise coming from the left front tire. What do you think that could be?
Old 04-28-2005, 03:35 PM
cukilo's Avatar
Default RE: Clicking noise from during low speeds?
Could it be the CV joints and how much are they to replace if it is?
Old 04-28-2005, 03:44 PM
aRIf's Avatar
Bushing maybe !?
Old 04-28-2005, 04:32 PM
TomRitt's Avatar
cv joint
Old 04-28-2005, 04:33 PM
cukilo's Avatar
How sure are you that its the CV join? How much are they to replace?
Old 04-28-2005, 04:56 PM
BFlan2001's Avatar
it is your cv joint, for sure....you have a few though, outers and inners for each side...i think the outers are more likely to fail than the inners....they are about 150 each, including installation, at a mechanic....
Old 04-28-2005, 05:13 PM
TomRitt's Avatar
^^Yea outter are more prone to failure, i have no idea how much the replacement is
Old 04-28-2005, 07:21 PM
brrman's Avatar
agreed cv joint
Old 04-28-2005, 11:29 PM
dafrazi's Avatar
Agree. Probably CV joint...most likely outer. Don't bother replacing the CV joint. Replace the entire halfshaft assembly (both joints). Replacement halfshaft is around $150 with core charge..with labor and core refund whole bill should come out to about $170 plus cost for alignment.
Old 04-28-2005, 11:46 PM
Jestnomen's Avatar
6th Gear
http://www.audiworld.com/tech/misc27.shtml
Quick Reply: Clicking noise from during low speeds?
