Sponsored by:
Sponsored by:
Clear Corner Mod Help URGENT!!!
Old 05-24-2007, 04:31 PM
d3m0nz3y3's Avatar
Default Clear Corner Mod Help URGENT!!!
Well i decided to finally do the clear corner, but i am having such a hard time removing that yellow reflector. I have been drilling for the past 1 hour now trying to eat that yellow tab from the back side, but the stupid reflector wont come off. I am at a point where i can just break my light lol.... any advice or help... i dont know what to do now :<
Old 05-24-2007, 04:35 PM
Jeff's Avatar
Zombie Defense Force
Default RE: Clear Corner Mod Help URGENT!!!
have you tried to crack the reflector to break it out? thats what i did and i was able to pull the tabe up after i did some drilling
Old 05-24-2007, 04:39 PM
d3m0nz3y3's Avatar
Well i was trying to drill the tabs out, but its so hard drilling the whole tab out. Maybe the hole in my houseing is small (i didnt want to make a big hole). I guess i will try breaking the reflecter out now. Hope that works...
Old 05-24-2007, 04:46 PM
Jeff's Avatar
what kind of drill are you using? i used a dremell with a grinder bit thing
Old 05-24-2007, 04:51 PM
d3m0nz3y3's Avatar
i am using a 5/64 bit. one question how big of a hole did you drill in the black housing at the back to grind out the tabs?
Old 05-24-2007, 05:01 PM
Jeff's Avatar
have you seen the write up from www.audiworld.com that might help you out a bit. its been a long time since i did mine
Old 05-24-2007, 05:08 PM
d3m0nz3y3's Avatar
Yeah i actually read all the mods written up... dont know whats wrong with mine. Cant get this thing to work, and i think i am pretty much fvcked my headlight now also [:@]
Old 05-24-2007, 05:09 PM
edge19lw's Avatar
Well if its like a B6 then:
your suppost to drill vertical holes on thetop tab and the bottom tab (where the clear plastic is (underneath the rubber you remove) not from the back of the light, then move it out with your finger or a screwdriver through the hole where the turn signal bulb is (remove the bulb). watch out not to scratch the inside housing!
Old 05-24-2007, 05:24 PM
d3m0nz3y3's Avatar
Yeah i read the B6 one, and its not like that. I have to drill holes from the back to get the tabs out. Damn didnt know it was going to be this big of a headache to get the stupid tabs out [&:]
Old 05-24-2007, 05:43 PM
StevenTownsend's Avatar
wait so is it a b5 or a b6. if it's a b5 just keep eating away at the tabs untill you can move it loose with something like a screwdriver. or do what jeff said, puncture it so it breaks more easily. just keep trying
Quick Reply: Clear Corner Mod Help URGENT!!!
