Clear corner mod.
Old 01-17-2008 | 02:22 PM
Ldetter's Avatar
Default Clear corner mod.
I want to do the clear corner mod to my a4 but am a little concerned about having trouble getting the car inspected once its done. Whoever has this mod done, do you haven any problems with inspection?
Old 01-17-2008 | 02:24 PM
FACT's Avatar
Default RE: Clear corner mod.
I tried it and completely failed. I couldn't get the damn little orange pieces out so I gave up
Old 01-17-2008 | 03:00 PM
drp1489's Avatar
you just have to be patient and keep at them.. shouldn't be that difficult though
Old 01-17-2008 | 03:09 PM
EVOLA4's Avatar
I did both of mine in about 15 minutes. A little stratigic dremeling is all it takes.
Old 01-17-2008 | 03:15 PM
Ldetter's Avatar
What about any problems with inspections?
Old 01-17-2008 | 03:27 PM
pimptrooper3000's Avatar
its not illegal in all states... u shouldnt be having problems with inspection the worst thing that could happen is some D!ck cop desides to pull u over but i doubt its gonna happen...
Old 01-17-2008 | 03:38 PM
Ldetter's Avatar
I live in PA, I know they can be dicks. I think i should be alright as long as i keep the amber bulb. I just dont want to cut the amber piece out and then have to worry about getting new headlights if they wouldnt pass inspection.
Old 01-17-2008 | 04:50 PM
Bogie's Avatar
make sure you register the car and go through inspection first, then do the clear corner mod. you don't have to go through inspection on a regular basis in PA, do you? even for regular emissions testing, i don't think they'd care at all about your headlights.
Old 01-17-2008 | 05:21 PM
Ldetter's Avatar
Every year i have to do regular inspections plus emissions. More than likely though they probably wouldnt even know theheadlights aremissing the amber corners being that they will still be the stock headlights.
Old 01-17-2008 | 07:24 PM
Papachristou's Avatar
ORIGINAL: FACT
i just used a small drill bit like 3/16th or smaller maybe and drilled straight through that tab at the top and bottom then stuck my finger in the turn signal hole and broke it loose... i used an L shaped pick from sears to pull it out from between the housing and turn signal piece then jiggled it around till the curved reflector lined with with the curves needed to removed it, once i got it inline to remove, i stuck that L shaped pick on it and just janked it out, ive also heard of people using needlenose pliars to break it in half once its close to coming out....
if you are unlucky some jackass or police will notice...
