Sponsored by:
Sponsored by:
Check Engine Light Update....
Old 06-13-2006 | 08:57 PM
sntemp's Avatar
Default Check Engine Light Update....
Today while I was at work my wife carried the 2001 A4 to Auto Zone to get diagnostic test done. They said it was a "vacuum leak". Anyone have experience with this problem? What should I check first?
Old 06-13-2006 | 09:31 PM
david9999's Avatar
Default RE: Check Engine Light Update....
Your vacuum hoses.
Old 06-13-2006 | 11:55 PM
Jovian's Avatar
Yeah I had a vacuum leak about 6 months ago. It was a hose going to my DV
Old 06-14-2006 | 12:04 AM
north5995's Avatar
if you have some cash, you could bring it to a garage and get them to perform a "leak test". They use a smoke machine to find where its leaking.
Old 06-14-2006 | 12:30 AM
JettaRedII's Avatar
There are a number of grey/black valves that deteriorate often and need replacing. I've had to replace three on three of my Audis. The ones next to the air box on the firewall side seem to go the most often.
Old 06-14-2006 | 12:35 AM
Jeff's Avatar
Zombie Defense Force
you could make your own pressure tester system
Old 06-14-2006 | 01:11 AM
cary12's Avatar
Post the codes that were found and it could be narrowed down a lot better. A lot of the time, the people at auto part stores don't know anything about European cars.
mikeysline06
11-04-2010 10:32 PM
parlayin
02-10-2010 12:33 PM
MrTigz5254
03-07-2008 11:56 PM
blanthony
03-25-2006 01:18 PM
Quick Reply: Check Engine Light Update....
