Check engine light, but I thought i fixed it!
Please help! My check engine light is on, the one that puts the car in "decreased performance" mode. I read about it in the manual, and it said that it could be the catalytic converters, which i knew where toast. I got one of them replaced, the other I need to save some money for, but the lights still on.
Another part of it is that if i've been "spirited" driving, when i come to a stoplight, it searches for it's idle, and has died 3 times while at the light. sometimes i'll come to a light from high rpms and it'll just keep going all the way to 0 and die, then come back alive and search for idle.
Any ideas?
Any ideas?
RE: Check engine light, but I thought i fixed it!
don't know.. it just said in the manual that it would be "Operating with decreased performance", could be like limp mode that bmw's have dunoo though.
ORIGINAL: sandnsnow24
Any ideas?
Any ideas?
i figured it out, and it's a simple fix. ya HB, you're right it is the o2 sensors, i got my cats fixed but the ecu wasn't updated or remapped.
Here's the fix:
Disconnect the battery connection, so the ecu has no power. Step on then brake a couple times, and hold it for a little, maybe 30 seconds. Reconnct the battery, and viola, remapped ecu and probelm solved.
If it's a serious problem it'l come back on. Luckily mine didn't
Here's the fix:
It doesn't "remap the ecu". It just clears out the saved values and faults. You don't have to hold the brake down either. Just disconnect the ECU or the battery for a half hour or so.
Here's the fix:
Here's the fix:
