check engine..... !!!!!!!!!!!!!!!!!!!!
RE: check engine..... !!!!!!!!!!!!!!!!!!!!
I take it your cel is flashing and you have minimal power with stuttering performace??? If its driveable, go to auto zone or advance auto parts and get your ecu scanned. Come back and post the codes here. We will keep you from getting ripped off/spending $6k to get it fixed. Its probably just a misfire from a bad coil pack. The fault codes will tell us which cylinder(s) is missing, if that is in fact the problem.
why dont you take the bov off and put the the dv back on and reset you ecu, drive for little and see if the problem is till there. i messed around with the bov for a while bc it sounds nice i know but its not worth it thats why i have adjustible bov/dv gfb valve but i used it for dv.
ORIGINAL: Sacha1.8T
6k???????? are u serious....
i have a garanty,.. is it possible to reflash it stock and give it.... unless its cheaper than 6k...
thxxxxxx
thxxxxxx
joeynach
08-27-2011 06:57 PM
parlayin
02-10-2010 12:33 PM
