Changing right headlight bulbs
Did anybody change a headlight bulb on the right side if A4 (2001)? Because of an airflow house (?), it’s impossible to access it from inside as it can be done for the right side... Appreciate your inputs.
thanks
thanks
RE: Changing right headlight bulbs
the accordian air hose just pops out. Compress the sucker and it will lift out. Then you can access the head light. Then remove the outer cover for the headlight. It'll be obvious when you get to it. The bulb size is a H7.
