CEL P0301
RE: CEL P0301
and when i turned the car off and let it sit and when i turned it back on smoke was coming out of the exhaust it was white smoke and alot of it but then it stopped and the check engine light came on for cylinder 1 misfire.
RE: CEL P0301
Sounds like a misfire in cyl 1.
swap coil packs and see if it follows the coilpack. Otherwise, you are probably looking at a bad ignition control module, or injector. You can also check the plug and see if it is wet with gas, eliminating the injector.
You can use a voltmeter to see if you are getting current on that coil pack wire. If not, its the ICM, or really bad wires.
RE: CEL P0301
That is probably the bad coil pack. You can confirm the problem clearing the code and moving the coil pack to another cyl. Start the enigne and if the code now shows misfire in another cyl, you have found the problem. Coil pack about 22 dollars.
