cel codes
cel codes
Well cel light came on again so I went out and bought a car scanner. I scanned the car and here are the codes that came up. 412C (Misfire detected), 412E (Cyl.2 Misfiring recognized), 465A (Voltage supply kl.30 voltage too low), 4085 Bank1-(Probel Signal too slow), 45AA Tank breathing valve-N80 Open circuit. Does anyone know how I would go about fixing those error codes. The one I am most worried about is the misfire one.. Any advice would be greatly appreciated. By the way it also gave me these codes but they weren’t in the book. H2, H2-E, H3, H4, and H1.
RE: cel codes
Here is a link to the scanner I purchased. http://www.uiftech.com/cpx.asp?id=204
What do you mean the numbers are off, There is a pdf link on that site that tell you what the meaning of each number is.
RE: cel codes
Well like your misfire for non-vag scanner should be p0300 p0302. Anyway check your plugs and your coil for cylinder two. Do this by moving cyl 2 coil to cyl 1 and see if the misfire moves. The voltage code sounds like you killed your battery or its low. The n80 I think would be your purge valve. Hope I helped.
RE: cel codes
I wil move the coils around and see what happens. How do I tell wich one is cylinder 2 though? Also as for the battery I had it replaced about 2 months ago. And as for the purge valve is that something I should replace where is that located... By the way thanks for all the help so far...
RE: cel codes
ORIGINAL: cas4067
sorry it took so long for me to responed been king of busy. It is a 01 a4 1.8l turbo 5spd...
RE: cell codes
your code reader is ok for you but the codes mean nothing and would take too long to decipher into P codes which is the norm [ p0300 p0302 ] this is the problem when there are so many different code readers out there ( go for one that gives Codes not the type you have ) plenty on eBay for a few $$
