car studders
Old 03-26-2007 | 03:48 AM
fobyulous's Avatar
Default car studders
hey all, i noticed today that after i give the car a little gas in park (bring the tach to 1500 rpm or a lil more) and let off the pedal the engine seems to studder. is that a sign of a bad/clogged fuel filter? i plan on replacing it soon, just wondering. also if not, what might be causing that problem?
Old 03-26-2007 | 06:02 PM
ironman's Avatar
Default RE: car studders
i would check out the intake, if under power the engine doesnt studder and when u lift off it does it may not be able to suck in enough air at quick as it needs. Try putting in a K&N high Flow, part number 33-2099 i looked while im at work i need one to. K&N really doenst list the part as being for this car but its the correct size.
Old 03-26-2007 | 06:09 PM
SacTown_Vlad's Avatar
Ccold engine???
Old 03-26-2007 | 06:12 PM
alias747's Avatar
May car does the same thing. It is quite annoying, when I do it with the AC on it does it REALLY bad.
Old 03-26-2007 | 06:36 PM
fobyulous's Avatar
i have a cone filter, it was cleaned recently so i doubt that is the problem. It also happens when the engine is warm.
Old 03-27-2007 | 02:59 AM
Vaudi's Avatar
Add some injector cleaner when you do that fuel filter
aznmpr
06-23-2008 11:27 PM
