car hard to start after refueling
Old 05-15-2007 | 12:57 PM
mack29730's Avatar
Default car hard to start after refueling
i have a 1998 audi a4 quattro with the 2.8 motor everytime i put gas in my car it will not start i have to let the motor turn over for about a min then it will start run rough a min then it's fine until i get gas again any idea on what this could be?
Old 05-15-2007 | 01:04 PM
Cloudy Audi's Avatar
Default RE: car hard to start after refueling
My '99 burps 3 times and then runs fine, it does start right up though. I noticed this even if I don't fill it up all the way.
Old 05-15-2007 | 01:06 PM
mack29730's Avatar
same here no matter how much i put in it acts this way.
Old 05-15-2007 | 02:44 PM
x1rider's Avatar
most likely evap canister problem, I had that happen a few years ago. I could only fill up the gas tank 2 gallons at a time and the engine would have to turn over a little while before starting.
Old 05-15-2007 | 09:21 PM
david9999's Avatar
It is most likely the EVAP purge valve right behind the air filter box, or the one way check valve connected to the purge valve. The valve is about 50 dollars and it is a 10 minute DIY replacement.
rccks96
08-29-2023 09:58 PM
jowing
08-05-2012 06:03 PM
socaljoe
B7 Models
12-30-2010 10:36 PM
neidermayer
03-18-2008 01:59 PM
FOUR Os
11-27-2006 11:59 PM
