Can you attach your ground wire to the bolt holding the stock amp?
Old 03-14-2007 | 03:05 PM
banderson121's Avatar
Default Can you attach your ground wire to the bolt holding the stock amp?
I'm installing my subs and I need to know if it is safe to use the bolt holding the bracket holding my stock amp for the ground. I was afraid any current running through the ground would mess up my stock amp. Thanks for the help
Old 03-14-2007 | 03:13 PM
new2me's Avatar
Default RE: Can you attach your ground wire to the bolt holding the stock amp?
I guess it would be ok, personalyidont like to use the same ground.What's the reason for using that bolt instead of something else?
Old 03-14-2007 | 03:19 PM
Because im installing an aftermarket amp. it needs to be grounded to the frame of the car
Old 03-14-2007 | 03:29 PM
new2me's Avatar
I know that! I was asking why that ground instead of the seat belt or another bolt. Just to be on the safe side.
Old 03-14-2007 | 03:36 PM
I couldnt find another bolt that i could unscrew all the way and put back in. the amp kit i have requires you to take the whole screw out, place the circle ground wire thing on the screw, and then screw it back in
Old 03-14-2007 | 03:38 PM
Audi_Skydiver's Avatar
I did that in my car and never once had a problem. And I was running 800 watts through it.
Josh
wood_e's Avatar
I assume you're taking the stock amp out?
Old 03-14-2007 | 03:39 PM
oh you attatched it to the stock amp bracket bolt and it didnt mess it up at all?
Old 03-14-2007 | 03:42 PM
ORIGINAL: banderson121
Yeah the bolt that holds the amp to the rear deck. I used that one and NEVER had a problem with it.
Josh
Old 03-14-2007 | 03:43 PM
new2me's Avatar
I used a bolt that attaches the carpet wall in the trunk to the baffle board. I used it because i mounted the amp on the baffle board. If there is a bolt that you would really like to use but cant remove it, you can always mod the wire ring or pick-up a open endconector.
Quick Reply: Can you attach your ground wire to the bolt holding the stock amp?
