Can someone explain the control arm/tie rod failures for me?
Old 12-14-2004 | 09:44 PM
rx7drifter's Avatar
Default Can someone explain the control arm/tie rod failures for me?
Can someone explain this, I have the SLOPPIEST damn steering in any car I've ever had. I just had an alignment done and within 2-3 weeks it's gone to crap and pulls to the right very hard. Tire pressure is good (i've had problems with this before).
-Mike
Old 12-14-2004 | 09:49 PM
audiboy1618's Avatar
Default RE: Can someone explain the control arm/tie rod failures for me?
rx7drifter- what year is car? I have the same problem. My b5 pull slightly to the right and has started to make some noises. There is a recall on them, call audi of america and give them your vin. They will fix it.
Old 12-14-2004 | 10:07 PM
rx7drifter's Avatar
It's a 1998 A4 2.8 30v 5spd quattro.
Old 12-14-2004 | 10:08 PM
a224932's Avatar
I have an 1999.5 Audi A4 1.8tqs, do you know if this affected this year and model? Does the dealer pay for the cost of the repair when it is a recall?
Thanks!
Old 12-14-2004 | 10:14 PM
clconversion's Avatar
Yes the dealer will pay for the part & labour just go to your local dealer and get them to punch in the V.I.N. to see if your vehicle is one that is covered under the recall
Old 12-15-2004 | 03:17 AM
mikehh's Avatar
I just replaced both sides front lower link rods. Gets the squeek away. Let me know if you ever found out how far back the do the recall.
Old 12-15-2004 | 04:04 AM
SlimChriz's Avatar
tie rods? wheel bearings?
Old 12-15-2004 | 06:19 PM
bitjanitor's Avatar
I was under the impression that it is a persistent problem across many years...and that you'll end up replacing them multiple times.
me == tie rod ends replaced last summer, rt. inner replaced yesterday. front control arms last summer also at the same time as the tie rod ends.
Old 12-16-2004 | 12:14 AM
PaulA4's Avatar
So it's the lower rear arm that sqeaks? Anybody confirm that? I'll go rip them off tommorrow if it is, the sqeak is driving me mad!
Old 12-16-2004 | 03:45 AM
vanhanz's Avatar
are you all talking about the car sounding like a cricket chirping at low speeds? I have a 2001 2.8 quattro and thats what mine sounds like. Or is this a different problem?
