Can driving "wrong" cause brake lights to come on?
Old 09-17-2007 | 12:47 PM
lkruvant's Avatar
Default Can driving "wrong" cause brake lights to come on?
My brake lights keep coming on and staying on for no reason even though I have had the brake light switch replaced. Is there some sort of driver error that could cause this? It's very annoying as it changes the transmission and can drain the battery overnight. 2004 A4 1.8T Conv.
TIA
Old 09-17-2007 | 12:55 PM
ironman's Avatar
Default RE: Can driving "wrong" cause brake lights to come on?
If you ride your brake or dont know how to not let the car COAST then maybe you can go through pads every month out other then that no,
Old 09-17-2007 | 12:58 PM
onepoint8tee's Avatar
Pretty sure you got your answer in this thread:
https://www.audiforums.com/m_641319/.../tm.htm#641342
How does it "change the transmision" and why do you think you are "driving wrong"?
Old 09-17-2007 | 06:30 PM
lkruvant's Avatar
I have had the brake light witch replaced already, but after a month this began again. No I am not riding the brake pedal. Sometimes the transmission cuts out (can't accelerate momentarily) when the brake lights come on.
The shop said "it may be the way you're interacting with the brake pedal."
Old 09-17-2007 | 06:32 PM
david9999's Avatar
Check the brake switch under the pedal again. Sounds like there is a short or bad connection.
Old 09-17-2007 | 06:33 PM
Its gotta be the brake light switch, again. Who replaced it? The dealer?
Old 09-18-2007 | 12:10 AM
lkruvant's Avatar
A local shop that specializes in Audi. This seems so simple.
twenty8red
08-09-2023 06:34 AM
JeremiahandfayJohnson
Audi Q7
04-21-2013 02:05 PM
mauigts
09-21-2012 07:28 AM
bmx672
04-03-2008 06:52 PM
ski_chick
10-19-2004 07:12 PM
Quick Reply: Can driving "wrong" cause brake lights to come on?
