Camshaft positioning sensor???
k well since i bought my car ive had the CEL on so i went and checked it out at autozone...it showed that my camshaft positioning sensor is what made that turn on...autozone told me 95 bucks for it...but my cars running fine i think.....im getting revo..forge 007...and new spark plugs all for 640 this week and im trying to see how big of a problem that sensor could be? ..need some help thnx guys
RE: Camshaft positioning sensor???
I had the same problem, replaced the sensor, still had the code.... car ran fine.. come to find out the previous owner tried to do a timing belt, they didnt set the timing right, timing was off by about 4 teeth.
This would be an important fix before getting Revo and other performance mods. I had the cell come on because i changed my timing belt and disconnected the sensor with the battery still connected, so the computer detected a fault in the line. (that's the only way i can explain it) Anyways all i did was disconect the battery and the code has been gone for a few months now.
Try disconecting the battery to see if the light comes back (may take a few days) or just replace it for the $95.
holy crap i cant believe the car was running 4 teeth off thats crazy
ORIGINAL: DGAFxxx
yea but 4 teeth usually means valves being reshaped by the pistons and alot bigger probs than some misfires lol, you my friend are a lucky SOB
ORIGINAL: DGAFxxx
it ran... didnt have as much power as it should, also caused quite a few random misfire codes.
