A/C recharge: A DIY project hopefully?
RE: A/C recharge: A DIY project hopefully?
Alright i'll break it down for you guys, i don't care which one is larger or smaller you can only connect to the low side anyway.
Yes after you remove the a/c 134a and oil from the system you are "supposed" to put the system under a vaccum for 15-30 minutesto boil off any extra refrigerant and get all the excess oil out so it doesn't get caught in the compressor/lines. You more than likely have a leak so re-charging it would be stupid. Using charging cans from autozone or whatever usually contain PAG oil in them so even if you get the right amount of refrigerant in the system without evacuating it correctly you can get too much oil in the compressor and it will cycle on and off preventing the a/c from working correctly. The pressures will look ok on a manifold gauge but you will notice the compressor cycling off and on again because the compressor is saturated with PAG oil. My advice is to take it to a pro with the correct a/c equipment to handle such a job.
Well, I put in a large can of the R-134a, but the guage on the line never read any higher than before I started. It continually reads right at the border of the "needs filling" and the "full" shaded areas on the guage, and the pressure never went any higher than 25 or so. But, I did hear a slight hissing from the area around the ports and - not sure if it's a leak or normal behavior with the refrigerant coursing through the ducts....
2000 Audi A6 Avant 2.8 Quattro
I did it on mine two years ago. The can contains R134a gas. Remove the plastic cover
in front of the windshield. On the passenger side of the battery you'll find the high and low
pressure A/C connections. Use the low pressure one only it is closer to the battery. Buy the cans from WalMart that contain R134a, lubricant and a guage.
