A/C Evaporator replacement, should I?
I've been dreading this. My evaporator seems to need to be replaced. I'm deciding if I should do it myself. I was doubtful if I should do the turbo myself. I decided to do it and it all worked out well.
Who has done the evaporator? Would you do it again?
RE: A/C Evaporator replacement, should I?
Newer done one but working under the dash of an audi is a pain in the ***. Its definatly not a simple job. What makes you think you need a new evaporator? Ive never seen one go bad.
man it is a pain i tried to inspect my ac drain line cause my car was leaking water on the floorboard and i though i fixed it but now hot as water is comming from under neath the dash it use to be cold water leaking in now its hot i dunno if i have a bigger problem the dash is all in the way such a pain
