Sponsored by:
Sponsored by:
Bullsh*t or not?
Old 12-20-2006, 05:12 PM
audiant's Avatar
Default Bullsh*t or not?
just picked up a pair of springs(eibach's) and i take it to AAMACO cuz i got a freind there and the guys says that one the 1.3 rear and 1.4 front drop will rub my fender. w/e im willing to take the risk. now he quoted me at 600 for the install saying that im also gunna need wheel alighnment and headlight alighnment! True or false? help me out guys (what did u pay for ur installs)?
Old 12-20-2006, 05:43 PM
Cruiserhead's Avatar
Default RE: Bullsh*t or not?
yes you will need a alignment and headlights-it depends on you and how much the new coils changed the angle and range of your lights but he's not lying.
600 sounds expensive but i've never priced these things. do it yourself and save some bucks
FLEX_rs's Avatar
i payed 200 for intall and laser wheel allignment all round install
Old 12-20-2006, 05:45 PM
Lazer Viking's Avatar
it wont rub, thats bs, unless you have like 19's
Old 12-20-2006, 05:49 PM
im for the B/S also
Old 12-20-2006, 06:02 PM
swift_A4's Avatar
you do have new shocks too right? otherwise you will be paying again for install and alightment. I would call bs on the $600 but you WILL need an alighment after which is like $100. w/ a drop of 1.3 i think the headlights will be fine.
Old 12-20-2006, 06:21 PM
audiant's Avatar
thanks guys...i just got a new quote from anohter guy for 250 just the install no alighnment. will i be okay with out the alighnment will there be any serious consequences if i dunt?
Old 12-20-2006, 06:27 PM
Default RE: Bullish*t or not?
wheel alignment??? why your only changing the springs and 1" is nothing, just keep an eye on tyre wear on the front then if it wears a lot then get the tracking done
Old 12-20-2006, 06:30 PM
luvin_the_rings's Avatar
DIY!!!
Old 12-20-2006, 09:59 PM
TDRILL's Avatar
ORIGINAL: avant80@2.6
Why run the risk of wearing out $600+ in tires in 10k miles just because you didn't want to put out $100 for an alignment. Maybe it all goes back close and will be ok, but any change in your suspension geometry can cause alignment problems.
Also, doesn't changing out the springs involve popping at least three of the control arms on each front wheel? Not to mention the rear and the use of a spring compressor. Having battled with a DIY full front control arm replacement, $600 doesn't sound unreasonable to me for all four wheels including the alignment and head light adjustment. With proper tools and a lift, one hour labor per wheel at $80/hr is $320 plus $100 for alignment. Your in the ball park.
Make sure that guy who said $250 knows what he is doing. I wouldn't touch your car for only $250.
Quick Reply: Bullsh*t or not?
