Breather tube crack
Old 05-30-2007 | 09:20 PM
PandaXpress's Avatar
Default RE: Breather tube crack
theres a recall on that you should check in wit ur local dealer casue they should replace it or pay u back if u got it fixed already
  #22
Old 06-04-2007 | 03:42 PM
dxl2749's Avatar
finally replaced hose....took forever but finally managed....no more oil and gas smell coming in through the dash vents and the car seems to be running smoother...could just be psychological.
  #23
Old 06-04-2007 | 04:49 PM
akielb's Avatar
Here is a stupid question - does the crankcase breather have anything to do with the boost/vacuum system?
  #24
Old 06-04-2007 | 04:54 PM
dxl2749's Avatar
right after the plastic tubing that connects to the crankcase there is a T. one tube goes to the PCV valve which is connected to the main intake tube after the air filter....the other tube goes through a few valves and finally connects to the intake manifold. so.....did that just confuse you as much as I already am?
  #25
Old 06-04-2007 | 05:00 PM
akielb's Avatar
if its connected to the PCV (pancake valve) then its in the system - I just ordered one last week from ECS tuning $46 for the S-tube and the T. but I have to wait for my samco TIP to get in (wed or thur) before they ship it to me. can't wait to fix it
  #26
Old 06-04-2007 | 08:44 PM
u not hear me there was a recall for it
audi would have done it for free
  #27
Old 06-04-2007 | 10:06 PM
akielb's Avatar
What year is this recall on? Do you have a link to it or somthing that says there is a recall? - I looked in the "Recalls" at the top of the page when you said that but it doesn't say anything about the crankcase breather in my available recalls for my 98.
  #28
Old 06-05-2007 | 08:46 AM
akielb's Avatar
VOLKSWAGEN/AUDI
38513
2544
V
7/28/2006
2002 < MODEL YEAR THAT IS COVERED
A4, Passat
2ADXV01.8342
The crankcase ventilation hose is broken or cracked and shows visible signs of deterioration. In most cases a MIL and / or oil leakage and / or engine starting problems will occur. Remedy: A recall has been issued to replace the crankcase breather hose with a new hose of improved material.
77106
CL(CA+NLEV ALLS)
77106
So this recall is for Model year 2002 only - everyone else is stuck doing it yourself
  #29
Old 06-05-2007 | 11:18 AM
dxl2749's Avatar
yep thats what the stealership told me....sorry no recall on a 2000.
  #30
Old 06-07-2007 | 08:11 AM
akielb's Avatar
I found this link - its a great write-up on how to replace the entire PCV system. But you can pay attention to only the breather hose if you want.
http://www.scottweese.com/images/pcv/pcv.html
Quick Reply: Breather tube crack
