Breaks- Help Please!
This kinda sux for a first post, but I need help. I just purchased a 2003 A4 1.8t Q 10 days ago. After having the car about 3 days the blinking red break light came on and started beeping at me. So I did some searching on here and found out the two most likely things were low break fluid or worn out rear pads. The pads looked fine so I added break fluid and the light went away only to come back 2 days later. So yesterday I took it to the dealership and they flushed the break fluid and said I did not have any leaks. well today the light has come back on for the 3rd time. Do u guys have any ideas as to what may be causing this problem? Thanks in advance.
RE: Breaks- Help Please!
Did you buy it from a dealer? If you did, go in and raise hell. They won't want to fix it, but they will. It looks like you've only had the car for a couple of weeks, every dealer is required to offer some warrenty, even if it's only a month. If they won't fix it, tell them that you want your money back, then they'll fix it.
thanks for the help guys. just got back from the dealership and the guys said that when my break fluid was bleed the right rear cap was not tightened enough and i was leaking from there. which would seem to make sense to me given how fast i was leaking fluid, but im a newb. this sound right to yall?
