Brake light mod question
Hey~ I did the Brake light mod a couple nights ago and I just noticed that when I hit my brakes the fog switch on the dash lights up. when I let off the brake it goes off again. Anyone else have this happen? or is this something weird since I upgraded from 98.5-99.5+ tails. No real issue with this just thought it was weird
Thanks
Thanks
RE: Brake light mod question
ORIGINAL: smokeU
were your tails wired for the other rear fog light already? mine is a 2001 and that port isnt wired or I would have had this done a while ago...
ORIGINAL: 96audia4
Thats normal...if you turn your rear fog lights on, your brake lights will come on as well.
but if you do turn on your rear fog lights with that button, yes the fogs and brake lights will light up, you will also blow a fuse, the "rear light" fuse. if your in an automatic car and blow this fuse then you wont be able to get out of park.
ORIGINAL: akielb
Thanks
Thanks
i also only spliced into one tail light. and the circuit board isnt that easy to solder onto. that diy write up should be changed realy becuase 1. you cant solder onto the board becuase the solder wont stick, 2. too much heat on that board will fry it and 3. you shouldnt be pressng the rearfog light button becuase you'll start blowing fuses.
yea its normal just be careful and dont turn on the fog switch then hit the brakes cause my friend did that and they got brighter then pop it blew a fuse so be carefull but u can still turn the fronts on so who cares about the rear fogs
ORIGINAL: Dirtbmxer2690
