Sponsored by:
Sponsored by:
brake fluid leak
Old 02-21-2007, 07:59 PM
selfemployed03's Avatar
Default brake fluid leak
I seem to be losing brake fluid like its goin out of style. i looked at the resicoir while i was refilling it, and it felt loos and when i moved it, appeared wet and what not at the thick black rubber spacer/seal attached directly to the bottom of the resivoir. any easy fixes, or am i gonna have to pay the audi specialists up the street a gagillion dollars?
Old 02-21-2007, 08:03 PM
CRAZYHAWK's Avatar
Default RE: brake fluid leak
Top it off and see how long it takes fot the
(O)
indicator to appear.
Old 02-21-2007, 08:37 PM
toaster's Avatar
the price of that repair has actually gone up to 2 gagillion dollars.
Old 02-23-2007, 09:03 AM
sandman's Avatar
well if the leak is right there under the resevoir then it will be an easy fix and you should do it your self.
Old 02-23-2007, 12:49 PM
ye ai know it looks easy, i just need to know what i need to tighten... it just feels loose... andyone know where to tighten that?
Old 02-23-2007, 01:08 PM
[IMG]local://upfiles/12092/698A70AF57114E3EB54226CB9DCBB1B2.jpg[/IMG]
Old 02-23-2007, 01:12 PM
item 12 are rubber seals and the header item 10 just plugs in so it will have movement that's the way its meant to be, perhaps you dislodged it somehow and it needs putting back in right
Old 02-23-2007, 01:33 PM
anybody have ideas for how to drain it so i can get to the bottom of this?
Old 02-23-2007, 01:39 PM
you only want to drain the header so syphon it out then just pull the header out and check the seals, you can buy new ones so not expensive
Old 02-23-2007, 11:36 PM
sandman's Avatar
turkey baster.
Quick Reply: brake fluid leak
