BOOST PROBLEM
BOOST PROBLEM
so check this out i just installed a AWE boost gauge on my 2004 A4 1.8T. i have a APR chip and when i floor my car the boost spikes at 19-21 lbs. so heres the problem when i floor my car the boost holds at 17-19lbs. tell i get up to about 4000 RPMs. after 4000 the boost start to drop the higher the RPM's the lower the boost drops. at my red line my boost is at 7-5 lbs. i know the boost will drop through the RPM's but why does it drop sooo much?
RE: BOOST PROBLEM
where is that? i was told by APR that the computer is going into safe mode and thats why the boost drops so much. so yeah i still dont know if anyone can explain this please do.
thanks
nick
thanks
nick
RE: BOOST PROBLEM
this wouldn't be the sensor... seeing as it sounds like it's reading correctly until higher RPMs. Yeah, definatly shouldn't be dropping to 7 at all. If i were to guess, I'd say you're starting to see a very small vaccum leak...
