Sponsored by:
Sponsored by:
Boost Measurement
Old 04-06-2005, 04:06 AM
Aliel's Avatar
Default Boost Measurement
Guys I want to measure my boost because I have a feeling that its not quite right. I don't have a boost gauge and I actually don't want to buy one yet. I have vag-com though. Is there any way I can measure it with it or something else with out having to buy the boost gauge?
Old 04-06-2005, 05:14 AM
ImolaS4's Avatar
Default RE: Boost Measurement
Boost is in the VAG-COM. I forget which number it is, but it's there in a few locations.
Old 04-06-2005, 10:04 AM
Aliel's Avatar
Is it real-time reading or it just logs it?
Old 04-06-2005, 10:52 AM
Jestnomen's Avatar
6th Gear
I thought boost logging was only available for drive by cable cars.
Old 04-06-2005, 11:48 AM
audihere's Avatar
Banned
when ur in neg vac that just means ur turbo hasnt spooled right and then once it hits 0 it has come to the point where its about to make boost correct.
Old 04-06-2005, 11:58 AM
Aliel's Avatar
I know for sure my car is not a drive by wire because it is an early 99. I checked with vag-com for a while today in the Measuring Blocks but I can't find a boost reading. Maybe I'll just buy a cheap gauge at pepboys or something and install it just to check it and remove it.
Now the other question is how hard/easy is it to install a generic boost gauge?
Old 04-06-2005, 12:02 PM
Jestnomen's Avatar
6th Gear
Here's a tutorial: http://www.audiworld.com/tech/elec48.shtml
Old 04-06-2005, 12:33 PM
Aliel's Avatar
I read it but it doesnt really explain how to install it. Do I connect it to the line that runs from the intake manifold?
Old 04-06-2005, 12:45 PM
audihere's Avatar
Banned
go to audizine.com and go into the diy section. it has a write up for a b6 but its the same thats what i went off of
Old 04-06-2005, 05:46 PM
brrman's Avatar
Boost is normally logged with block 115. VAG doesn't have a fast sampling rate,
so it might miss a very quick spike. But for logging purposes it does the job.
Installing a boost gauge is simple as hell... My sedan...
Quick Reply: Boost Measurement
