Boost Guage Installed
Installed boost guage today. Took a hole 1:30. Nice an clean install to.
Im boosting 6psi in 1st, and 7 psi 2nd-5th. vac is 10.5 solid.
Ready for Chip/DV now
Done so far : Air box mod w/ K&N. 4 new tires. Boost guage.
RE: Boost Guage Installed
you will be suprised when you see your boostgauge going crazy after you get chipped i spike around 19 psi mabe 1psi more or less some times but its nice to have a boostgauge knowing that air is flowing without leaks
Its a cheap guage. Nothin pretty. Its a faze, pod. Mounted on dash, left of steering wheel. I plan on dumping all my xtra money on the motor. All go. no show. My vac tester is pulling 10.5 hg from the T split. So I know its not my install. Boost is consistant. vac is low. Any ideas?
