Boost gauge // PSI questions.
RE: Boost gauge // PSI questions.
that there's your problem (at least part of it). pepboys used to carrycrap - sunpro (although i had a set for temporary use and they worked), and the really good brand- auto meter. i never had a netami gage, but my guess is thatpepboys replaced their crap with more crap. i would get autometer againat least for the quality. good luck
yeah, someone else already returned it, or opened it up to steal a gasket or T fitting out of it or something, or had a bad one and bought that one and returned the bad one to the store. shame on you for buying open box without checking it out first. did you get your $30 back at least?
sure your not in limp mode? when you go WOT it should read 8, and when your lighter on the gas it should boost lower. but if you got another netami gauge, it might just be that. did you hook it up to the dv vac line or back by the fpr?
#20
damn thats sad, get that thing flashed by anyone!
my b6 boosted 9 maybe 10 stock and held 7/8
since getting my flash and my R1 fixed i spike 23lbs and hold 20lbs
great feeling actually getting to see the needle wrap around the boost gauge!
