Sponsored by:
Sponsored by:
Boost gauge failure or am i chipped? *Update*
Old 06-01-2006, 02:47 AM
whitejeepXJ's Avatar
Default Boost gauge failure or am i chipped? *Update*
First of all yes ive used the search and i havent found what im looking for.
Specs on the car: 01 A4 1.8T 5spd Quattro (stock, well supposed to be)
Ok heres the deal. I bought this audi about 4 months ago and i love it so far, it has the sport package and drives very well. I bought a boost gauge and installed it on the vaccum hose on the top of the intake manifold the closest side to the rad (basically the front)....so the hose thats closest to the grill. Im reading 14 hg vac at idle and about 17psi in 1st and in 2nd-3rd- and 4th i hit 20 psi...
Gauge failure?
Leak?
didnt install it on the correct hose?
chipped?
Ps. My check engine like came on a couple minutes after i took the car for a spin when i installed the gauge..
Thanks for the help
Michael
Old 06-01-2006, 02:57 AM
BadLuckAudi's Avatar
Default RE: Boost gauge failure or am i chipped?
id check to make you you didnt disconnect the wastegate by accident that could cause the light and those numbers
Old 06-01-2006, 03:26 AM
BaconBait's Avatar
Get your car code scanned. If you don't have a vag com, go to autozone and they will do it for free.
Old 06-01-2006, 03:31 AM
ejc317's Avatar
where do u guys have these autozones - i have one in NH and the ppl that work there are retarded lol -
Old 06-01-2006, 03:32 AM
yea there isnt one anywhere even remotely close to me lol
miked's Avatar
yeah but they can rent you a vag.
Old 06-01-2006, 03:36 AM
they usually done have vag coms i thought just generic code scanners
Old 06-01-2006, 03:47 AM
Dj Spiel's Avatar
You gauge should not be CONNECTED TO front line by grill. It will read 10-14 for vac pressure
It has to be connect to closest one by windshield. Will read 19-21 for vac pressure
Old 06-01-2006, 03:56 AM
no it should read the same in either spot, i hooked mine up in both spots testing it out and it worked in the front just fine
ORIGINAL: Dj Spiel
Old 06-01-2006, 05:32 AM
b6driver's Avatar
ORIGINAL: BadLuckAudi
yup... and they only scan when you get an engine light..
Quick Reply: Boost gauge failure or am i chipped? *Update*
