Blue Smoke
Blue Smoke
When I start the car in the morning (I live in sunny California so its never that cold) it spits out blue smoke. I've owned this car for not even 2 weeks and I am starting to think that I should have stuck to my 96 C220...
RE: Blue Smoke
Well It could be leaky valve seaks. The oil leaks into the combustion chamber while it is sitting, and when you start up it is burning off. How many miles does your car/what year? Please include specifics here when you ask questions.
Is your oil overfilled?
RE: Blue Smoke
Right I already explained why this happens only when you have a cold start. Over night the oil has had time to leak through the leaky valves and pool in the combustion chamber. When you start the car up it is immediately burned off. Oil creates blue smoke when it is burned. Once the car is warmed up there is not a substantial amount of oil burning to create any more blue smoke, even though you are probably still burning small amounts.
RE: Blue Smoke
Ah, did some searching and found this.
Are valve stem seals all I need? 20 of these: Valve stem seal link
Did this a while back on a different car, I'll at least definitely need a special tool, though.
I just ordered the Bentley CD along with the air, fuel and ACC filters, so I guess I'll find out soon enough. Anyone know a good source for special tools? I can't seem to find any. []
