Blower Motor - Found The Problem
My blower motor hasn't been blowing, managed to get to it via the pollen filter end. When I've turned the fan on it doesn't turn but when I nudge the blades off it goes spining and turning. I've sprayed WD40 to try and loosen it up. Once its running its okay but when I turn it off and re-start it wont turn yntil its given some help. The mechanism feels smooth and it doesn't appear to be binding? Is it time to get a new motor?
RE: Blower Motor - Found The Problem
[sm=bustedsign.gif]
wow your lucky - nobody has flamed you for opening a new post when you already had one open about the subject lol
first post YESTERDAY
I'm so glad my name doesn't say newbie anymore - This means I'm no expert but I do know how to read and search first.
And above all I know not to open a new post just to update a post I made the day before
[sm=badbadbad.gif][sm=badbadbad.gif][sm=badbadbad.gif][sm=badbadbad.gif]
[sm=guilty.gif]
[sm=shutup.gif]
[sm=guilty.gif]
[sm=shutup.gif]
^^^^^ NOOBIE!!!! ^^^^^
haha, like I have much room to talk, I've got more posts, but you've been around longer! And as far as the Blower motor goes, thats rather wierd. How hard is it to pull out? If it isn't too bad, I'd maybe pull it out, rip it apart, and rebuild it, if at all possible. Maybe it'd work then.
Thanks for your worthwhile response. Correct, I am a 'newbie' and yes I'm still getting used to using the forum. I'll take onboard the point you make but at the same time I'll ditch the sarcasm that surrounded your point.
