Sponsored by:
Sponsored by:
Best turbo setup for long term daily driver
Old 08-25-2006, 01:37 AM
tatman9999's Avatar
Default RE: Best turbo setup for long term daily driver
ko4 i have it its great
Old 08-25-2006, 03:09 AM
18T's Avatar
18T
18T is offline
ko4 is as far as you can go for DD reliability!
get the j31 file! some nice numbers there!!!!
Old 08-25-2006, 03:47 AM
flyinb501's Avatar
K04 is the most reliable turbo upgrade available.
Old 08-25-2006, 04:07 AM
b52000a4's Avatar
is the eliminator a t3t4 or is "t3t4" a flange type or what? and jeff what is "anti lag"
Old 08-25-2006, 04:13 AM
BadLuckAudi's Avatar
the elim is a gt2871rs, t3t4 is what jeff ran which isnt all the common but a good set up with the right tuning, and antilag is something you can run on a custom ecu its where
When the driver lifts his foot from the gas pedal the ignition timing is altered with sometimes 40° or more of delay (retard) and the intake air and fuel supply mixture is made richer. The inlet butterfly is kept slightly open or an air injector is used to maintain air supply to the engine. This results in air/fuel mixture that keeps getting in the combustion chambers when the driver no longer accelerates. The ignition being delayed, the air/fuel mixture reaches the exhaust tubes mostly unburned. When the spark plug fires, the exhaust valve is starting to open due to the ignition delay mentioned above. Additionally, the exhaust temperature being extremely high, the unburned fuel explodes at the contact of the exhaust tubes. Luckily the turbo sits right there and the explosion keeps it turning (otherwise it would slow down since its intake, the exhaust gases, is cut-off). The effect is vastly lower response times with some downsides:
A quick rise of the turbocharger's temperature (which jumps from ~800°C to the 1100°C+ region) whenever the system is activated
A huge stress on the exhaust manifold and pipes (mounted on a street car a bang-bang system would destroy the exhaust system within 50-100 km)
The turbo produces significant boost even at engine idle speeds
The explosions which occur in the exhaust tubes generate important flames which can, sometimes, be seen at the end of the exhaust tube
Reduced engine brake
[/quote]
Hauschild
05-26-2012 08:19 AM
Keppelmanj
03-01-2010 04:08 PM
Four Ring Circus
03-03-2008 03:12 PM
ldtikk
10-05-2007 12:30 AM
drucat
06-01-2006 06:57 PM
Quick Reply: Best turbo setup for long term daily driver
