Battery problem????
Battery problem????
Problem need help.......
I just sarted up my A4 this morning but it sounded like it was battery was dead....tried multiple times and finally started up fine....
I had the same issue 3 weeks ago and audi inspected it and said I need a new battery which by the way I spent about $190 for it.....
Is this a battery issue or electrical problem???
thnx for advice and inputs.....
2001 A4 1.8t Q, 55K
2001 A4 1.8t Q, 55K
RE: Battery problem????
Sorry to hear that. Circumstances like that can catch us all out from time to time. It sounds like the battery is not charging. Could be a bad cable, poor ground, altenator, etc. Start looking at the simple stuff first. How many miles?
Get the car started and check the voltage. The alternator should be putting out about 13.5+ volts. Use a digital voltmeter.
If charging looks ok then check for something that doesn't turn off, like the trunk light or interior lights or a short.
