Bailey's Diverter Valve
i'm looking to buy an aftermarket dv, i'm thinking about a bailey's, and i was wondering if anybody knows if they can be opened for cleaning and replceing the spring. i think all aftermarket dv's are serivceable but i just wanted to make sure, and i read that the forge springs will work in the bailey dv's, if so what spring color should be used? i always read different colors and different rates...sometimes i hear that the blue is the strongest and sometimes it the yellow...can somebody tell me what the correct rates are? thanks
RE: Bailey's Diverter Valve
i actually just bought a forge 007 and i was also wondering what the best spring for the dv would be. sorry to get in on this thread boober but i have the same question hopefully we get an answer.
Well the different springs go for different PSI levels. I am using the green spring, and I peak at around 21psi. So really you need to know your psi and then find the corrosponding spring.
as to whether or not forge springs work in a bailey's, no idea
ORIGINAL: Ford2Audi6
ORIGINAL: chaos92287
a couple of bailey's dv's are up for sale in the classifieds section right now for 100. they're normally 150. might wana check it out
does anybody know if the forge springs will work in the bailey's?
