Bad smell + peanut butter on dipstick!! HELP...
Old 03-21-2005 | 07:36 PM
docurley's Avatar
Default RE: Bad smell + peanut butter on dipstick!! HELP...
Classic symptoms, low water and a peanut looking oil HEAD GASKET is gone for sure.
If you keep driving it your kill the lump you may also notice quite a bit of steam from your tips
Old 03-21-2005 | 07:42 PM
Sebass's Avatar
Do it ASAP! My sister just kept filling her Blazer up with coolant as it needed it thinking it wasn't a severe problem...then finally when coolant smoke started billowing out of the hood she decided to get it fixed and car ran great......two weeks later CEL comes on, car dies on highway, Bye Bye Engine! Whole new crank kit needed...the damage had been done....
Old 03-21-2005 | 11:15 PM
Shaunp05's Avatar
Have them Check out your Car ASAP
If wat u saying in ur past post is true then most likely
its the head gasket, have ur Tech run some test first
leak down test etc make sure So you know wat to expect
Old 03-22-2005 | 09:39 AM
david9999's Avatar
Likely head gasket, but could possibly be the oil cooler if you are lucky.
Old 03-22-2005 | 10:22 AM
Jestnomen's Avatar
6th Gear
I thought a bad oil cooler usually meant oil in the coolant, not the other way around?
Old 03-22-2005 | 09:39 PM
Shaunp05's Avatar
That can happin,, the fins in the Rad are eroded by the high acidic levels of the coolant and
can cause oil to seep through as the is a pressure differencits and circulate with the coolant and produce the cream look.
Old 03-27-2005 | 02:34 PM
Furrystump's Avatar
You definitely don't want to run the car. As stated before hydrolock is a very bad thing. Also the spot where the gasket is blown will eventually erode the aluminum head. If it goes to far you won't be able to cut enough off to make the head flat again. From this point things just get more expensive. Sorry to hear of the bad luck. If you catch it early it is not too hard to change out the gasket. I've done it on other motors too many times.
Bad Justin
08-27-2008 04:02 AM
SouthernAudi
10-11-2007 07:13 AM
A4speed
09-03-2006 01:41 AM
mll
06-06-2006 02:39 AM
Quick Reply: Bad smell + peanut butter on dipstick!! HELP...
